You can remove the tap, and soak it in carb cleaner to ensure all debris is gone.
Also you can unscrew the dirt trap that’s under the tap (it’s a cap  than needs a socket/spanner to unscrew it off)
Then it is pretty much ready to go.  You may not need to replace it unless there is a leaking concern with it (ie. orings)
