Ben
Ok so, fitted the new starter relay and tried starting the bike. And then the starter motor would’nt shut off! The black/white cable running to the negative terminal has melted and most of the ground cable in the harness has also melted. So I’m assuming I have a short somewhere along the harness.
So does anyone have a wiring diagram for the gt125r as I’m starting to loose patients with this thing. Thanks in advance!
