Peadar
  • Topics: 6
Hi Jan. If you look at what moves on the engine when you twist the throttle where the cable is attached should rotate on both sides of the engine. If both move then cable is ok. If only one side moves then cable is most likely snapped. You described twisting throttle hard and if cable was badly adjusted then it can fail.
