Only after you followed the diagrams.
Then be *wise & careful* doing this. Have someone with you.
Bike on paddock stand.  Start it.  let it idle for 2mins.  Drop to 1st gear. See if the rear wheel spins.
Did the wheel spin? If yes step 2 below
Rev up while in gear. If it cuts. Its your carb or whole fuel system again.
This is assuming clutch is OK (the whole basket inside the motor) plus cable adjusted properly.
