Alan McLean
  • Topics: 12
Hi Marcel, I seem to have a problem attaching image’s to the post. I pulled the plugs today and took pictures I will send them to you via email if that’s ok. Both plugs look exactly the same the electrodes on both are white, also I took the bike for a short spin and it is running worse than the other day, still the flat spot but now when you blip the throttle it takes a few seconds for it to return back to idle, is this also a symptom of the problem. Also I have no Idea if the mixture screws have been tampered with by the previous owner 😔
