Alan McLean
  • Topics: 12
Hi Marcel, I checked all float levels when I was cleaning the carb’s, standard exhaust, new NGK cap’s supplied by you, and new battery. Slide needle’s set on third ring as per your tutorial. How do you clean the fuel pump? I’ve only ridden the bike once since doing all the upgrades, hope pilot jet’s aren’t still blocked 😔
Will take the bike out again tomorrow and check the plugs.
Thanks.
