Charles A.
  • Topics: 0
Hi, in the service manual, Chapter 4, the only thing close to that number is P0107
“IAP&TS (Pressure function) Circuit Low Voltage or Open”
The sensor should produce following voltage.
0.15 V ≦ Sensor output voltage
Without the above range for 2.2 sec. and more, the code P0107
is indicated.
Intake air pressure & temperature sensor, lead wire / coupler
connection.
or P0117 “WTS Circuit Low Voltage”
The sensor voltage should be the following.
0.1 V ≦ Sensor output voltage
Without the above range for 6.25 sec. and more, the code P0117
is indicated
Water temperature sensor, lead wire / coupler connection.
I don’t know if any of these are even close. The Dealer should have the Hyosung Diagnostic Tool that uses PC_Scan and attaches to the 4 connector near battery. I have and and used it on a bike that has a P0210 injector error. It will read code and give instructions. It can also test the ECU.
