Apr 27, 2020 at 8:23 PM
#4365
My set up is different to this , I donβt have two connections on the rear intake boot and the tank has no vacuum connector on it ,just two stubby connectors that connect to the fuel tap on the side of frame
It’s okay, the pre-05 had manual side mounted taps than a vacuum one.
So as usual the tank feeds the frame tap.
Then tap => filter => to rear pump.
The manifolds on the engine will only feed the rear pump. Both joined in a T-piece then single line towards the rear pump.
