Mar 1, 2020 at 6:23 PM
#3913
If the bike uses original filter and exhaust , then its a full stock machine. Also check lambda/oxygen sensor thats in the pipe too. If you had a service book next to you, may prompt the dash to display an FI error code that the ecu may tell you what’s the underlying issue ? Also consider to check intake related sensors on it too.
