Hey,
It sounds famously like the dreaded 60mph (95kmph) bug that happens to faulty coils or clogged carbs.
Remove your spark plugs and clean them   (50/50 chance they may need replacing if they aint sparking hard anymore)
Get a meter , put red wire inside HT cap.  Black wire on the frame.  You should read 6,000 ohms max (6k) for the coils .
Take a look below and learn how to remove carbs off the bike , then you can clean them.
– Take out the piston slides (black tubes) = clean with a cloth & its carb holes (piston walls)
(they control main jets)
– Get a carb cleaner & compressed air can (aerosol air) , and blow the jets clean from particles.
– Put the carb upside down, make sure the floats are 7mm high (not less , not more, just 7)
(full throttle fuel control happens here too)
LINK BELOW:
https://hyoriders.club/forums/topic/tutorial-hyosung-gv-gt-125-250-how-to-swap-carburetor-main-jets/
Let us know if that worked , before attacking other parts of the bike, as these 3 ^ above are usually main culprits  (plug | carb | coils)
