ThrashMasterFlex
  • Topics: 0
Thank you so much for clarifying that. The entire thing slowly started to make sense to me as I reread your words.
So if the EGR device can simply be removed, can I remove the T juncture in the Yellow line and just run it directly from the manifold boot to the rear pump?
Also regarding the leaking fuel cap. Since it does leak when turned upside down, is this something I need to fix or is it fine as long as I keep my tank right side up and not affect performance?
