- Topics: 1
- Country: United Kingdom
- Bike Model: Gv125s 2021
Hi all,
I know this is an older thread/post but I am having a very similar issue. Though mine is extremely intermittent.
for example I did my 2 mile trip to work and she was fine then left work and did a 3.2 mile ride to Hobbycraft and it was also fine. But leaving Hobbycraft to go the 5 miles home it decided to do it. I killswitced and turned off the ignition then restarted the bike and everything was normal again.
This has been happening for a few weeks randomly like this for both long and short trips. I have replaced my spark plugs and HT leads hoping this would solve the issue as my old ones were gone.
I have checked the idle throttle position sensor as above and the only thing I have noticed is in the airbox between the two intakes to the engine there is a crack/split right in the middle, it doesn’t go all the way through but could this be the cause? If so any ideas on what would be the best fix?
If it helps this all started happening after I went to a jet wash to clean the bike. (Original HT leads on at this time so this is why I suspected those being the issue.
Any suggestions would be much appreciated :).
