May 29, 2026 at 7:30 PM
#22685
Fuel Level Reading = Normally, sometimes my 2005 GT took 10mins to get levels ready , then the bars started climbing up. The RC EFi model will flash empty for a little bit then get readings once it settles.
If the sensor is dead = it wont say anything all day. It doesn’t need ECU as fuel sender goes straight to dashboard via yellow wire (if i remember correctly?)
Hyosung either used capacitors or soldered battery on the dash to remember clock time, but after many years it stops , so counter always resets. It never bothered me to fix it as i just look at the phone or my wrist for true time haha.
Delphi vs Mitsubishi ECU is up to you , whichever is a cheaper or quicker route for you!
