Would i be correct to say it sounds like an Ak47 in slow motion and where is the sound most loudest ? which exact part of the engine ? – Seems to be idling eneven, so also check your spark plugs incase one cylinder isnt burning properly
If the engine is cold, start it and put your hand on it and see if you feel anything that suggests something is banging against the walls ?
I am not able to decipher the video properly but my guess so far would be either clutch basket or top end
or one cylinder isn’t burning properly (causing uneven running?) – I haven’t even addressed the carbs yet (it will be the last thing unless plugs are pure white clean = no fuel in that cylinder)
Worst case scenario is that i really , really hope it is just a time to do valve clearances (if they were too loose , you would also get that Ak47 sound but usually happens at higher revs)
