Hey you mentioned, sometimes it has starting issues when on kickstand, is it bypassed ? and if yes , remove the bypass to check if the wires had internal corrosion, it happens sometimes with these new Gen RC machines. Also check your tilt-sensor or replace it ? if your mechanic can use a tilt sensor from another bike, it is also called RO Sensor (Roll Over), bike maybe thinks you fell down ? so it shuts off sparks & starting, it can happen, I am not sure it is a good idea to bypass it (heaven forbid the bike falls in the garden and it is still running!)
Hey Marcel,
Kickstand is bypassed, i can check the internal corrosion but i doubt its that since it ALWAYS starts when not cold, bike never randomly shuts down, etc..
about the tilt sensor, wouldn’t that make it completely impossible to start? would it be the tilt sensor even though it started at the shop numerous times, and starts with me but with the help of the throttle?
My main concern is fuel delivery since pratically every other component on the bike has been checked!!! any ideas other than a bad IAT sensor?, would the bike run fine with poor/dirty injectors? because it runs just awesome 🙂
I will test and try to turn the bike on while its on the kickstand to see if it fires up. Can’t do it right now because I just tested a key recycle many times to see if the issue was depressurization in the fuel rail. (it only fired after a bit of throttle like usual)
Thanks Marcel
