Welcome! Hope to see the completed upgrades you will post on the forum 🙂 Not many people do ECU flashes as they are afraid that a false move could mean they can’t get a replacement ECU , however , they try to improve the sparking a little bit , the most improved mods would be something like a 520 chain set and a good clutch upgrade for long summer trips. If you have OEM caps, replace them with NGK ones , that’s the only major electrical complaint people have in the UK , sometimes the stock caps ruin the coils next. And invest in a good regulator! That’s pretty much it. You could at your own pace upgrade the tyres too, so its less suicidal when riding in the rain, i was never a fan of the stock Tyres Hyosung used in the past. # I believe once you go 520, you won’t go back to the tiny chain 🙂
Omg thanks for the advice! Yeah an ecu flash is not something I’d do willy-nilly and especially not without first finding someone with experience with those kind of things to help me.
520 chain first, then probably clutch. When you say caps, what do you mean? I’m not used to all the jargon in English yet 😅
