Welcome! Hope to see the completed upgrades you will post on the forum 🙂
Not many people do ECU flashes as they are afraid that a false move could mean they can’t get a replacement ECU , however , they try to improve the sparking a little bit , the most improved mods would be something like a 520 chain set and a good clutch upgrade for long summer trips.
If you have OEM caps, replace them with NGK ones , that’s the only major electrical complaint people have in the UK , sometimes the stock caps ruin the coils next. And invest in a good regulator! That’s pretty much it.
You could at your own pace upgrade the tyres too, so its less suicidal when riding in the rain, i was never a fan of the stock Tyres Hyosung used in the past. #
I believe once you go 520, you won’t go back to the tiny chain 🙂
