Otherwise , clutch switch and sidestand switch (even if bypassed would have corroded wires inside the harness, strip back and see.) – I would NOT bypass a clutch switch though especially on EFi models.
Just quoting this , as those will cut sparks off too.  You did not say “Cuts out when going in to 1st gear ?”  ??     I could not understand your previous phrase “Bike shuts off when put into her intermittently”
So i will assume its electrical and needs stripping down to investigate either way and contact cleaner will definitely help if some pins or wires have oxidized bad causing a signal loss
