Mar 1, 2026 at 6:56 PM
#22054
I dont have those at hand as its not something i keep on file, but hopefully someone else does. Though, try to look for a crashed 250cc and ask the seller for the ISC unit, so you can double check but also clean your contacts (every plug on the bike including the ECU socket) incase of oxidized pins affecting ohm readings or water ingress found ?
Just an idea!
