I bought a used 2016 GT250R a few days ago that had come from a police auction. Aside from the obligatory mystery pinhole leak under the tank, obvious mistreatment damage such as busted peg, home repaired peg mount, fuel cap keyhole busted out, missing start button, etc, the thing will start by jumping the solenoid under the seat, but will only stay running after repeated starts and it will die if I increase the throttle. It wonβt reach 3000 rpm without dying.
Amazingly there do not seem to be any wiring splices or hot-wiring done at all, nor are there any other leaks aside from the underside of the fuel tank. That said, when I turn the key on/off to get error codes on it I see FI on the LCD and the F1 light it gives me this:
10 5 10 5 10 1 3 1 10 1 7 1 7 1 10 1 7 4 10 1 3 7 10 5 10 10 10 and it repeats.
I found the 4 and 2 pin jacks under the rear seat and attempted to bridge the 2 pin jack to see if it would give me an error readout on the display but I get nothing different.
That should read 10 5 10 5 10 1 3 1 10 1 7 1 10 1 7 4 10 1 3 7 10 5 10 10 10
