Terrey
  • Topics: 2
  • Country: Australia
  • Bike Model: GV650
Hi Marcel,
I really appreciate your help. I tried the Fuel System liquid as per your suggestion in the tank and looks like 95% of the issue is gone. It doesn’t have any problem when I am riding in the morning when it is a bit cooler, but in the afternoon, I still feel there is a slight issue, but certainly a lot better than before.
I used the full bottle of Fuel System liquid in the tank and will do it again if required. I haven’t checked the thermostat yet but checked the fan which does work. I can feel the heat on my legs in the afternoon from the engine, but the bike temperature doesn’t seem to go more than 3-4 bars which is normal. I will check if the thermostat is the problem and let you know if it is defective. Thanks again.
