Daewoo pumps run at a different pressure rating, did you swap the internals of your OLD pump in to the new plastic shell of the new pump ?
And retry?  Also if possible , check if there is a 12v pulse coming from the pump wires when you turn the bike on ? (this is what turns the pump on to prime, so its a wire / signal check)
As you had the bike apart, you want to use only dry air , and blow the connectors clean for every plug you find on the bike.  I would not even think twice to put liquids near the ecu ,as you said,  you would have to go in hell to even find another Daewoo ECU again, so i too hope it is not that either.
