I think I have the only GV250 in Hawaii haha.
Find hawaiians on social media and see if there is a biker community there and ask around, you will be surprised there could be one more. I am suspicious we have a member on here with a GD250 EXIV model but i could be wrong,  if its true it could mean they have not posted in the forum for a long while.
In regards to your starter issue.
Replace the starter motor first,  and crank on full throttle with a new relay. Test and report back ?
You can also carefully , extract the flywheel out of the bike and look at it ,   if it is under 10,000 miles old,  I don’t expect issues with the flywheel system yet i hope not.
If in doubt, upload here what you see.
If you drain oil,  replace it with Motul 7100   (very very good oil!)  and get a fresh oil filter.   Better to replace oil OFTEN as you like to keep the engine healthy as possible.
I change oil every 1,000 miles on my bikes.  It is OCD / Crazy but i’d rather waste the oil than scream at engine replacements lol.    The local recycle plant should take your old oils and they will re-use it for something else  so you’re not killing the enviroment.
