Hey Robert!
Welcome and yes the drain plug vs the gearbox plug.  I wish the gearbox plug had a warning engraved under the casing to say “do not open this  unless rebuilding gearbox!” but we would still miss it if the underside is very mucky!
Did you also test the rest of your electronics to make sure they are all up to date ? See the topic below:
Ignore that it says GT125 , that’s its younger carb based sister but principle is the same.
Make a new topic with your findings  ie…. “Electric tests on a GV250 EFi”  ,  and we shall comment to see if you’re in good hands.  There is also a service manual in this forum too for the EFi Gv250 too. It goes in to much more detail on how to test various sensors , so you’re caught out on a long trip , because a previous owner was neglectful towards it.
It’s a lot! – but take your time, do it bit by bit.
Forgive me if you can’t post pictures , I am fighting some bugs under the hood until you see a nice yellow-green button that says “Add Media / Upload Pictures”  , i don’t want the site to be too technical to browse around.  So i will be simplifying a lot of it & consolidating the forum , so its more unified.
Stay safe out there and 76 is a nice age , keep riding sir and stay warm this winter!
If i may ?  Don’t use or fit heated grips ,  rubbish stuff… and very taxing on the stators and regulators.    (If you replace a regulator,  replace the stator unless the stator proves to be in good spec on your multi meter readings! – very crucial)   — Go on Google and look for  “KIES HEATED APPAREL”  very good brand,  they have heated gloves, vest , shoes , etc …. and they use their own power-brick which goes in your pocket.  You can walk around feeling nice and warm , and charge the power brick at home after your trip.
Now that leaves the bike’s stator (already at max capacity) to feed the regulator and various & various(!) sensors scattered under the hood.
Regards
