Yes actually i was able to spin the flywheel with my hand and it spun clockwise from the perspective of the starter clutch assembly pretty easily almost with 0 resistance and i wasnt listening for the hiss of the pistons but i didnt hear anything either i dont know how audible its supposed to be but that fact alone might answer your quesion since i didnt even catch the sound by mistake. Also What i said about by oil coming out of the intake pipes that was A mistake I am not 100% sure of where the oil came from but all I know is that the entire side of the engine was coated in oil and it makes it very difficult to see where the origin was from sorry, my mistake, lastly I did not try bump starting it, a very good idea could definitely tell me a lot right now I’m heavily leaning towards the idle gear and the starters pinion not sitting together correctly and causing a jam because when the starter is in the bike, I could not turn the flywheel either direction. It would stop all movement but after I try a bump start, I’ll update with the results thank you for the advice
