Do you have a short somewhere ? Ie parts of the harness touching the frame or…… 2 plugs are both 2 pin. One is for stator sensor One is for reg to harness Its easy to mix those two up & the harness gets fried or reversed terminals on the battery. 14.5V is usually the norm but 15V is Hyosungs limit as per manual. Disconnect your lights and see if bulbs affected them? I replaced my 4yr old bulb 3 days ago as the resistance grew so much the wires got too hot! Happy to test your reg again if you want to be extra sure as i did promise warranties provided the bike doesnt cook either the stator or reg & a new AGM battery is used (no lithiums) Confirm stator makes 65v-85v at 5k revs on each yellow wire via AC (service manual pn forum has tutorial) with reg unplugged?
just a follow up question, those 14.5 to 15 volts, are they at 5k rpm or idling? Because mine showed 14.9 when it was idling
A bit too high 14.9 when idling  – Should be 14.0-14.4v – but we can tolerate 14.5-14.6 as normal too.
Hyosung’s limit is 15V so you’re just on the border!
but OEM or Knockoff regulators are just wild = they would jump around from 11.5 to 16V! = 16V is basically time to blow up the battery or cook everything that’s attached to the harness that needs a 12v source.
Check yours again at 5,000 rpm  (as per service manual)  and tell us ?
