When the lights go dimm, it means 3 things
- I know its tested but i highly bet the battery drops volts and amps as fast as you press “start” , because it’s asking to spin the starter, supply power to cdi and coils etc to spark 10,000 volts pulses to the plugs to fire up.
- Solenoid could be gone yes
- Starter Motor has gone weak (thus causing extra battery drain) – Replace it or open it to inspect starter motor bushes but drain bike oil first before removing starter motor.
Also when lights go dimm, does the dashboard go dimm too? do you hear a click ? buzzing like flies? or thud-thud ?
hello my bike is currently doing everything as you explained at the bottom, i installed a new starter motor and it started a few times but once after i forgot to put the kick stand up and now it wont start at all it’ll crank for only so long then go dim and buzz then make clicking noises and shut off it’ll turn back on if i keep holding it but it just drains alot what can i do ?
Best to make a new topic , so we can isolate your specific issues.
Quick answer = Battery, Charging System (Stator & Reg) , Poor Sparks . More of that in your own new thread and try to report back if you followed my replies to this topic also so i can avoid repeating things like if the battery is brand new and what brand it is etc.
