Oct 9, 2025 at 9:58 PM
#20969
Looks like Iām going to have to split the case, drum will not rotate freely so most like something binding on it.
Before splitting the case up, spin the flywheel to see if the clutch drum rotates too ?
If you were spinning the wheel in neutral, the pistons would stay still meaning the crank doesn’t , but obviously if its in gear , it stops you rotating the wheel freely by hand
