Sep 23, 2025 at 8:12 PM
#20871
Was able to get the head off, there was a hidden nut, (had to remove the 2 hex bolts on the side cover) and a 10mm nuts was there, some hammering and the heads off,
I got some pictures could you let me know if there’s anything visually wrong with the top of piston and valves pls? Gasket I think deffo needs replacing. (Just click the arrows to go to the next photo, should be 5)
