Sep 20, 2025 at 9:05 AM
#20816
Hello everyone, back again after a big trip, eventually have gotten some time to work on the Hyosung.
Had to double check the main jets as they look oversized for my bike, might explain why it splutters in top gears on the throttle.
Went down the path of electrics today as high beam was not working, found out I may need a lh handle switches, I am about to heat up the soldering iron and give it another bash so its road worthy.
Rear brake I forgot about the lower nut off the caliper just spins, no tighter no looser, does not remove, cannot remember how I changed the brake pads like this, though they were changed but the brakes
are not working to spec.
