Shiby
  • Topics: 1
  • Country: United kingdom
  • Bike Model: GT125R
Was able to take out those bolts (kept going at it with a breaker bar then followed with impact) engines out. Now I took the cams, loosened the tensioner (ziptie on chain so it dont fall) removed every bolt i can see on the front cylinder, even the main 4 cylinder head bolts (long ones), and there were 2 hidden nuts near bottom on the outside, I removed them aswell yet head wont come out, the one side without those 2 nuts is coming put but the side with the nuts I removed. That side is stuck on, tried a bit of hammering and prying still no luck, even tried lightly hammering the exposed screw bit that had nut on yet nothing, how to I get it off?
