Sep 18, 2025 at 7:37 PM
#20800
I have also noticed that the previous had been messing with the left handle switch assembly (which controls the highs beams, indicators etc) and it hasn’t been properly closed when screwed back on as there is a gap so could it mean that water getting into the switch assembly could be cause the issue e.g. corroding contacts in the switch being pulled when handle bars are turned and have now broke?
Most likely , best to take it apart and use a meter to test the contacts and the end of the plug to check each pin has continuity etc , this will confirm if the switch is totally dead or some contact inside needs sorting or a broken wire inside the switch cable
