Shiby
  • Topics: 1
  • Country: United kingdom
  • Bike Model: GT125R
Ok, ill take the head off and have a look to see whats damaged, cylinder jugs Id most likely replace same with piston rings, if piston is damaged I will replace that.
I still couldn’t find replacement piston rings
The garages would charge a lot, id rather do this myself as its would be alot cheaper and insurance on this bike is kinda high so will need some money for insurance.
So for now only parts im looking to order beforehand are, piston rings
And if you have any links for good cylinder jugs
Replacing both heads, jugs and pistons due to cost of parts a replacement engine or even a different bike might be a better option unfortunately…
Will get this engine open tho and will have a look
