Compression test above
Ok soo hooked the auxiliary tank directly to carb. This time bike would always start with ez start (wouldnt start on own) but at least it would start with ez, bike sounded alot louder, and would rev, i was able to hold throttle at certain position (I haven’t been able to set idle yet but was trying) and by holding the throttle there bike stayed at 2k for like 2m and then started to rev higher by itself and then die. Obv required a couple start ups to get to that point. When feeling the suction pipe that connects to tank it had good suction. The fuel pipes ones from carb to pump and pump to tank had suction but wasn’t as strong as that (pretty big difference). I guess for now and further testing ill stick with the auxiliary tank as it did help get the engine started alot easier.
