Shiby
  • Topics: 1
  • Country: United kingdom
  • Bike Model: GT125R
Ok so the bike starts with easy start (pretty constant sprays) and idled for a couple seconds at 2k ish. Then does what is always did tried to die, was able to keeps the bike running after a couple more tries and had it running around 3k-4k for under 30s with some revs (revs were responsive after 3k-4k mark). The rear cylinder was hot, not the hottest, but hot and front was warm not hot, I kept trying wasnt able to get it started on easy start after that would try but then fail to run off tank.
Battery was charged before but may have lost some charge trying to get the bike hot, so not at 100% these are 1st try tests
Compression readings
Front: 95
Rear: 115
With oil in cylinder
Front: 145
Rear: 175
Tried testing with oil in cylinder again
2nd try but battery was dying then
So not sure if oil in cylinder test was low battery. (Did give good cranks tho when testing)
