Aug 24, 2025 at 8:16 PM
#20571
oh , make sure both plugs are out of the engine and do it full throttle for a few seconds fully charged, then you get some compression readings.
Also throw a little bit (tiny bit) of oil in the cylinders , and do a 2nd compression test again. Does it go up when the oil is added? (piston rings vs scored cylinders)
