Shiby
  • Topics: 1
  • Country: United kingdom
  • Bike Model: GT125R
Everything put back together i give crank, no start i then double check mixture screws then idle screw, fuel filter only 15% full when crank. I sprayed easy start yet almost turned on but then didn’t and drank the 15% from fuel filter, got it started only once, only way to keep bike alive was full throttle, and was at about 2k rpm, after like 10s she revved up and I could rev until i let it drop and it died (same issue i had before). (Also when running i had a look at filter and fuel drizzle in to it like small stream at bottom of filter) Even after new jets full carb clean new Everything on carb, new o rings yet still same problem after that start couldnt get it started, not even with choke or ez start, with ez start it sounds like it will start but doesn’t. What do i do now?, nothing seems to work… I still remember that time couple months ago I got it started and it started first time then a week later it just does what it does now… might give up on this bike
