LaserBeam
  • Topics: 14
Cool, Marcel, i’m glad you’ve done it. I have a scissor lift & a wheel stand – i just did my front forks. Happy to take exhaust off.
-The 17mm PIVOT will a normal socket fit? Or do they have to be really thin walled to fit on the nut?
– Do i need a 17mm socket on both sides of bike? One to loosen nut & one to hold?
– Did you use SOCKETS or RING-SPANNERS for the SHOCK LINKAGES? Not sure if i can get a socket in there?
– I thought i may be able to leave most of the SHOCK connected to the frame. And just undo the linkage & bolts that connect SHOCK to SWINGARM. Is that what you do? Or did you remove the shock from the frame too?
-----LaserBeam---->
