Disconnect one until the pump stops working , i can’t see without pictures as Hyosung moves relays around and sometimes don’t label them.
Eg. Disconnect a relay, and your lights dies == Label that one as “Headlights Relay”
Look for fuses , if there is a BOX with tiny fuses inside, the fuel pump one will also be there , if not , you will just see 1 fuse saying 15A for the entire bike but i highly doubt it. Big things like pump , regulators on the newer models are fused since they started using Delphi Electronics.
