Aug 16, 2025 at 10:58 AM
#20502
It will be in the battery area , so strip main seat off and you will see a rail with multiple relays on it.
On certain models of the GV125-S , Hyosung also puts a seconday fuse called “Fuel Pump Fuse” and is usually 20-30A
So yes you may see either a relay-only or Relay + Pump Fuse (Depends on Hyosung themselves)
