The clearances look good! , the compression should be good when it warms if it is showing 10kg cm2 cold.
The tensioner,  if it makes a noise then yes replace it because it seems like you replaced almost all other components inside the motor.
Do you think the cam shaft bearings & crank bearings are OK during your inspections ?
