LaserBeam
  • Topics: 14
I will send you a link to a carb kit & guide on how to install the bits. It can be easy but apply heat to the brass parts before your undo them .. heat the carbs all over thats what i do. Very hot. A bit too hot to touch, not too hot you cook the orings inside. Ultrasonic clean will cost too much but is a good alternative IF they look after you carbs. Can of Carb Cleaner, some tools, a table, a chair, some parts & you can make them better.
-----LaserBeam---->
