Jul 17, 2025 at 5:32 PM
#20049
To swap to the round headlights , yes you can , you have more chance here.
Fire up ebay, and get these (without skipping either, as they are all required)
- Nosecone Metal Cage for 2007-2010 models
- Fairings (Nose cone panels , older ones with brawny looks airvents onthe side)
- 2007-2009 headlight unit
- 2005-2009 fairing brackets (because the 2007 nose cone uses “S” shape yellow clips to mount the nose cone fairings to your ENGINE panels)
- Bottom Chin Panel (under the headlight, looks like a boomerang)
- Dash Surround Panel (needed!)
- Dash Mount (2005-2009)
- Screen ofcourse.
Now you just go have fun painting it all, i
This could workout being the quickest way to ago about things.
Oh yes , don’t forget (not critical but completes the look)
- Air Vent (left and right side)
- Infill Panel (mini triangle for the right side of the nose cone only , aka “inspection panel”)
Otherwise , 2016 “front end” is strictly for 2016 only – you can’t mix and match. You either want the older look (2005-2009) or the newer 2016 look
