Ryan
  • Topics: 1
Hi,
Thanks for the very detailed reply,
The bike is only 4 months old as it was a pre reg and has only done 3577 miles. If it is the clutch what should I replace it with?
The carb appears spotless inside and  the spark plugs seem to be a dark brown colour.
The place i bought it from has adjusted the carbs once or twice as he claimed they were too lean from the factory. However since then i have changed the jets and dont know if it will need altering again.
I dont think the gouge in the rubber goes all the way through under the carbs  and the lights do not dim when everything but engine is on.
Thanks.
Ryan.
