Hey Leo,
Got your service filter delivered?
And are you able to connect a spark plug  (MUST BE “CR8E” only , dont use other plugs like CR7 , CRB-EX9 etc.. like some twats do)
Then make sure battery is charged
Connect the spark plug to the HT cap  (front engine)
Disconnect the rear ignition cap too
Place the front spark plug to the “BOLT” on top of the valve covers ==> Do sparks come out when you try ?
Also do the same for the rear engine ?
Also , swap coils around
Here is the safest way to remove the airbox below to access the rear coil , take absolute care not to stress down the rubber intake pipes as they are more difficult to get and they split easy!  (can’t stress it enough)
Stop at step 5 on that link.
Let us know!
if anything looks suspicious under the hood,  click “ADD MEDIA” on this forum reply box as you write and click “upload picture”   to show us
If you get trouble uploading,  just post it to “OneDrive/GoogleDrive/DropBox”  and get a public share link so we can view this image.
