PaulGT250r
  • Topics: 5
  • Country: New Zealand
  • Bike Model: GT250r
Update from today.
Removed the front headlight and fairing.
Fount the wiring for the 2 pin plug is looped in with the headlight wiring.
Checked all the bulbs, all good.
Tested for power at the 3 pin plug to the headlight 3 yellow wires, non of them were live or had power, also checked with the bike running.
Headlight relay was no good so swapped it out and rechecked, still no power and headlight not working, high beam does work using the pass button on the left handle bar.
Checked and cleaned the switch on the right handle bar.
Could the issue be the ECU?
Tail light and rear brake light works with front and rear brakes.
Any suggestions?
Thanks
