Was the “Add Media” button not working on the forum ?
Also, in regards to the bolt stuck there…
  • Hairdryer ==> blow the intake hole on cold setting or compressed air.    Even a small rock dust will grind your piston rings  = compression loss or burning oil later.
  • Then plug that hole before doing repairs
    I suspect a dremel should do it  or weld a nut on to it?
    If not, drill through it , and use Heli-coil kit to rethread it.
Carb unit =
  • That hole in yellow circle means you need a hose attached there  and also in the MIDDLE of the carb —> join up with a T-piece —> 1 long hose to the road, this is overflow/breather pipe.   If the bike fell on the side where the coils are and fuel will come out of there 100% ,  if the hose is missing and coils get faulty  (arc-ing / sparks escape, its an instant fire!!!)
    Glad you noticed that!
  • Cylinder Heads = Find a way to remove as much crud as possible until its very smooth   (even attach a polish ball to a drill to smooth out the surface) then get new o-rings  , you can’t trust those ones anymore.
