Soo removed carb and used compressed air in every hole of carb and in jets, when carb was removed it was dripping fuel but not from the hose part ill send a pic and circle it, now the intake pipes while taking one of then off unfortunately i was unlucky and a bolt snapped was able to remove the intake pipes both of them and will send a picture of their condition, now regarding that bolt that snapped the head snapped and luckily there is a good chunk of the bolt still sticking out, soo i tried to remove with vice grips but too tight, any suggestions before i use mr dremel and put a line in center of bolt so i can remove with flat head?, cuz really mr dremel is always my last resort, back to the carb everything seemed clear the thread of the jets did have some white powdery stuff on it (wasnt on there last time) air passes through jets perfectly, could get some air in the main jet hole (the actual carb hole on carb not individual jet)but obv it has holes in it soo cant get that much air pass. Also checked front spark plug and it was basically same as i left it.
Should be 8 images below
