Strange,
When you click “Add Media”  on your Phone , click “Upload” button as shown below:
Then find the source of the picture  (In this case, navigate to your DCIM/CameraPictures Folder in your phone)
As for your GV, if there is no display cluster , it will run without it but ofcourse you need to see what is happening though.  Do you have a local breaker where you are to find a wrecked Hyosung GV250 EFi to get its dashboard? And possibly a spare ECU.
Since the bike is EFi ,  it uses an ECU only , so no need for a CDi  (for carb models only)
Based on your ECU, you have a 2009-2012 model which has a super super rare ECU  (that ECU is not made anymore by Daewoo, hence Hyosung upgraded their harness and ECU to Delphi Electronics after 2013+ – I hope that ECU of yours is intact.
If the stator looks damaged, that could be a source , check the flywheel isn’t damaged in any way  before it kills the next one as there is a very narrow gap between the stator and flywheel when it spins.
Hope you are able to upload a picture from your phone/pc to show us ?
If not , alternatively  upload pictures to imgur.com   and copy the “BBCODE”   —> come back to the forum –> click “TEXT”  (next to visual blue tab) in the reply box  , then paste the BBCODE here.   The forum will fetch the images remotely where you uploaded to imgur.com
I will do my best to recode this site again so its easier to make uploads here.
