There is a few youtube videos on guys with very old suzukis as they still had metal tanks,  some use vinegar, some use white spirit combinations and there was a product used to clean car tanks  (metal tanks of old 20th century cars) but keep forgetting the name of it,  some also use metal marbles and shaking the tank all day , then using magnet sticks to scoop out floating rust after the fluids have drained out.   There is many ways to do it   ,  just make sure the tank is fully dried out but if liquids touch the paint, be ready to cry and likely go to the bodyshop to get it resprayed properly.
Compression Loss as per manual, so i will quote it from the horse’s mouth:
Low compression pressure can indicate any of the fol
lowing conditions :
●Excessively worn cylinder wall
●Worn-down piston or piston rings
●Piston rings stuck in grooves
●Poor seating of valves
●Ruptured or otherwise defective cylinder head gasket
